I’m running Audacity 3.2.4 on a windows 10 64 bit computer.
I was trying to work with a m4a file and it requires a FFmpeg library.
I downloaded and installed in C:\Program Files\FFmpeg for Audacity the library, including the avformat-59.dll.
However after restarting Audacity it still complains about needing the dll.
I even went to the Edit->Preferences->Libraries and saw it said FFmpeg library not found
I went to the directory where the library exists to add the location but even then it fails.
I assume you can play the M4A file in another application? You know it’s good?
As a (hopefully temporary) work-around you can convert it to WAV with a 3rd-party application. (I have [u]Kabuu Audio Converter[/u] and [u]TAudioConverter[/u] which I use if I just want to convert a file without editing.)
FFmpeg is going to decompress the audio anyway so it’s basically the same process, but a couple of extra steps for you.
And of course, if you want to keep M4A format you can export as WAV and use the same 3rd-party tool to make the new M4A.
Yes, so you probably have 64-bit Audacity installed. However, it is possible to run 32-bit Audacity on a 64-bit Windows computer. To verify which 32/64-bit version of Audacity you are running, look at Help > About Audacity > Build Information > Build type.
