Trying to save a project on a Mac
When trying to save to desktop I get error message “unable to open target drive to save”.
Under “File > Export As” choose mp3 or m4a I think. When you click “Save” it chooses a default non-audio file. That can then re-open as you left it, THEN you Export As …
You probably do not have access to the location you have selected as target for your files. It does not look like it should be saved to your desktop. What is the default location in Audacity for files to be saved / exported to?
See Audacity → Preferences → Directories. If you always want to save to your desktop, populate the “Save” and “Export” fields like this:
/Users/yourname/Desktop
or, as I have it set to
/Users/myname/Documents/Audacity-Projects
/Users/myname/Documents/Audacity-Exports
In Audacity 4, the default path for exporting and saving cannot be set (yet).
