TROUBLESHOOTING AUDACITY 3.7.3 CRASH
Audacity 3.7.3 Thinkpad x220 Digitalisation 48000 Hz stereo zu mono
The following setup is used for digitizing analog audio reels containing up to 3 hours and 20
minutes of audio recordings.
Workflow: Revox Studer B77 MK II (refurbished) via Motu M2 or Motu M4 to ThinkPad X220
Debian Trixie Audacity 3.7.3 Periodic but irregular crashes—i.e., the program freezes and
Ctrl+Alt+Del is also unresponsive. So power off and on and save the Audacity project.
What can I do to find the causes of these regular crashes so that a solution to this problem can
be found? Identical problem on two ThinkPad X220s same workflow as for a ThinkPad SL 510 (Debian Trixie Audacity 3.7.3) which performs the digitization without any crashes. Thank you for helping ! kapsar
Are you saying it freezes/crashes DURING recording? If so, try using Ocenaudio instead (just to capture and save) while you look for an answer. There is a Trixie version.
