Win 10
Audacity v 2.1.0
Not sure if it’s .exe or zip.
In the best tradition of multiple learning styles, I’ve been posting both print & audio versions of my podcasts. This works fine when I’m working from an essay I’ve already written, but not so much for the classical podcast format of interviews. Transcription is time consuming.
I have Dragon Naturally Speaking voice recognition software on my computer. Is there a way to interface Audacity with Dragon (they are, after all both using digital renditions of sound) to produce transcripts?
According to this, Dragon Naturally Speaking can transcribe recorded speech from a sound file (this feature may only be available in the “pro” version - check your user manual).
Assuming that is correct, then you just need to export your recording from Audacity in a file format that Dragon Naturally Speaking supports. The export default format in Audacity is 16-bit WAV and I would suggest trying that.
Hey Martin - wow, this post takes me back! I’m the guy behind Audioscrape.com, and yeah, back in 2016, linking Audacity with Dragon Naturally Speaking was a tough nut to crack.
There’s no direct way to pipe Audacity’s audio into Dragon since they don’t really play nice together out of the box - Dragon’s more about live dictation than chewing through pre-recorded stuff from Audacity.
But man, times have changed! Nowadays, there are slick tools that’d solve your podcast transcription woes in a snap. Stuff like Whisper (free, AI-powered, great for interviews), Descript (edits audio like a doc), or even my own Audioscrape - we transcribe podcasts fast with 92% accuracy, perfect for pros juggling interviews.
No more manual slog! You still podcasting? What’s your setup like now?
Disclosure: I’m the maker of Risenote, so take this with that in mind. If you’re after transcription on an iPhone, Risenote makes AI meeting/lecture notes entirely on-device, so no audio goes to the cloud. It’s free to try: Risenote – AI Meeting Notes App - App Store . It won’t help with Audacity-side workflows, but it may suit quick spoken-word transcripts.
