Hi, I made a track and did something that moved the track off center and expanded (widened (looks like amplify but I didn’t amplify) the view of the track (its not louder just expanded wider than all other tracks) I fixed the off center problem but cannot figure out what I did that makes the appear amplified. any ideas? cheers
Perhaps you clicked on the vertical ruler at the left edge of the track? Doing so will zoom in vertically.
To zoom out, right click on the ruler, or “shift + right click” to zoom back to normal.
See: http://manual.audacityteam.org/man/audio_tracks.html#scale
yes, that fixed it, resolved - ty
