Track shows clipping but Analyze-Find Clipping does not find any
Hi,
I’m recording from an external (reliable) source using loopback and WASAPI. The track shows (very) few red bars but if I go to Analyze…Find Clipping, Audacity 3.3.3 does not show any clipping.
Why?
Thank you!
They use different algorithms.
One sample at or above 0dB will trigger “show clipping”. You can have a sine wave that touches 0dB without going-over or clipping.
“Find clipping” normally looks for multiple 0dB (or over) samples in-a-row, and there are settings you can change.
Neither algorithm is looking at the wave shape that wouldn’t be 100% reliable either because you could have a square wave or a squared-off wave.
OK, I checked the details, it’s always only 1 sample.
Thank you!
