подавление шума
после подавления шума появилась примесь в голосе. как её убрать?
Audacity Noise Reduction works in two steps. Drag-select some pure noise. Noise that has no voice. Effect > Noise Reduction > Profile.
Select the whole performance. Run Noise Reduction again with the three reduction values > OK.
Noise Reduction doesn’t work on noises that are constantly changing such as other voices or music.
If the noise is too loud, Noise Reduction will start to damage the performance.
