ive jus got a track thats way too bassy and would like to know how to reduce the bass? ive tryed the equilizer but cant seem to get rid of it :S
Did you take your camcorder to the rock concert? That’s not just too much bass. That’s your microphone overloading during the bass notes affecting everything else. Overload/clipping is one of the permanently fatal sound errors.
Upload a short segment of the damaged song.
https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
The easiest way to reduce bass is probably this plug-in: https://forum.audacityteam.org/t/tone-control-plug-in/16872/1
If that does not fix the problem then the problem is not just too much bass and we will need to see a short audio sample to find what the problem is.
