Hello All! I’m a newbie here and I just have a simple quesion about the the tone generator and I hope I can get some help. I’m using the tone generator to create binural beats for a project. That being said, I know I can create basic beats such as 4Hz (100Hz-104Hz), however, what I would like to accomplish are beats that are in the 0.4Hz (100.40-100.00); 0.04Hz (100.14-100.10); and if possible, 0.004Hz. (100.114-100.110). Is the Tone Generator in Audacity capable to create these beats?
Thank you,
AL
There is an (old*) Binaural beats plugin specifically for Audacity …
https://plugins.audacityteam.org/nyquist-plugins/generator-plugins/special-effect-generators#binaural-tones-with-surf-2
[ * it works in Audcaity3, it appears in the generate menu after restarting Audacity].
Surf can be turned off.
Thank you! I appreciate the quick response.
