Hi. Adding points with the Envelope Tool always cause a littlle ‘jerk’, an unwanted movement of the point; this is bothersome when adding points not intended to be moved but as ‘anchors’*, specially if there are no more close points near because the ‘jerk’ moves the Envelope possibly untill the end/beggining of the wave, and not knowing the exact value pre-jerk, it has to be corrected ‘guessing’ where the point would be without the jerk.
So I propose a (longer? if it exist already) ‘timer’ before engaging movement when one first click to create a new point, so new points remain unmoved for a little while more to be sure the user really wants to move it or letting it still if the user is creating just (for now) an anchor.
*‘Anchors’ seen in pic. This anti-‘jerk move’ is a complement to my proposal “Envelope Points in Waveform, more range of movement” https://forum.audacityteam.org/t/envelope-points-in-waveform-more-range-of-movement/52128/1 , and may have in part something to do with the fact that now the Envelope Tool is logarithmic, (there is a proposal [1+] to make it linear))
Thank you.
