Hi! I need help because the TB Timemachine addon no longer works. Presets do not change the settings for the effects, nor does manually changing and applying. This is the only plug in I know how to use to get good bitcrush. If anyone has a fix or an alternative plugin that would be great.
This workaround sometimes works with real-time VST3 effects in Audacity 3.
Pause playback, (NOT stopping), when real-time effect is being previewed, then mix down whilst paused to apply the effect with the settings/preset you have chosen, (rather than the plugin’s default settings).
