Hello,
I would like to know the time of the current placement of the selection tool.
In attached screenshot I can see from the timeline that it is between 13 and 14s, but how do I display the exact time of the selection tool?
Thanks
Hello,
Thanks
At the bottom of your screenshot (scroll down the screenshot) is the “Selection Toolbar”.
Click on the little black arrow at the end of one of the “time” boxes and select smaller units, for example “hh:mm:ss+milliseconds” (it is currently showing hh:mm:ss only). You will then see a more precise time in the Selction Toolbar.
Thank you ![]()
Is there any way to get it to display ss+ms instead of hh:mm:ss+milliseconds?
Sorry no, there are “only” 16 time formats to choose from.
