I’ve been using Audacity since Red Hat v2. The features I would like to see added shouldn’t be difficult. The first one is: let me set default display for such things as adding silence. I seldom if every use scales smaller than seconds. Why do I always have to reset to seconds?
Second: I have just about every effect and plug-in loaded because sometimes I need them, but not often. I would like to be able to set a favorite’s list. Sometimes it takes more time than it should to find the efect or plug-in I used last time.
Three: I am using a 4K screen and may soon be going to at least a 6K screen. I cannot adjust the windows to properly see audio settings. I have to stop what I am doing and go into preferences to see what I should be able to see in the windows. Sometimes I need digital settings and sometimes I need analog settings.
I hope these suggestions are not taken wrong. This is a great software and I have watched it grow into a program that can match the expensive packages. I am asking to have frustrations removed to make my job easier while using a great program. If you are not impressed with Audacity then I will say: You are not using it correctly!"
Good job folks!
