I downloaded Audacity 2 months ago, and since I installed it, I have not been able to modify the recording level, so it has been impossible for me to capture audios correctly. I have been using the program for 5 years without any problem, however, now that I have had to reinstall it, I have not been able to use it at all.
What is correct ?
For USB or loopback recording, the audio level is already set externally to the computer or to the recording system. Specifically, reducing the recording level will not eliminate any distortion. If the level is too high, use Amplify to set it where you want.
