You have placed the audio tracks (backing track, guitar, etc), and timeline is set to Beats and Measures. Timeline correctly shows the measure numbers from the beginning of the piece. To record vocals you need count-in. You can move the tracks to the right, and add the rhythm track in front. But now the timeline shows the measure numbers from the beginning of the count in, not from the beginning of the piece. Any way to achieve the intended result?
I think the best you can do currently is:
and then mentally subtract 2 from the bar numbers.
