I’ve recorded some Hydrogen drums along with Audacity’s own click function. Now I wonder… is there an easy way to check the tempo of the song? I mean, I might want to change the tempo later on and then it might be practical knowing the tempo. I haven’t saved any of the Hydrogen files, I only exported them as wav:s.
A very accurate way to determine the tempo of a click track, or a drum track, is to select an exact number of beats.
Here I have selected exactly 9 full bars of a 4/4 click track, so that is 36 beats.
As you can see in the Section Toolbar at the bottom, the length is 16.364 seconds.
To work out the bpm temp, divide the number of beats by the duration (36 / 16.364), which gives the number of beats in 1 second, then multiply by 60 to give the number of beats in one minute (bpm):
(36/16.364) x 60 = 131.997 bpm.
The actual tempo of the click track was 132 bpm, but our answer was accurate to within 0.003 bpm.
which will detect the BPM reasonably accurately in a few taps.
There are some experimental Nyquist plug-ins on this Forum such as Tempo estimation to detect beats then calculate the BPM but really you can work out the beat more accurately by ear or calculator in most cases.
The same way you created the Click Track in the first place. Generate > Click Track… and look in the Tempo [beats per minute] box for the value you last entered.
