T2-MP3 for Windows 10
I have a T2-MP3 converter which I bought for my last PC which worked on Window 7. I now have Windows 10 and it seemed to download the operating disc OK but it doesn’t work. Should it work ?
We only make the Audacity software, not the converter. What are the precise symptoms of “not working”?
Does Windows see the device in the Recording tab of Windows Sound and does its meter bounce there when you play the tape? If yes, try Transport > Rescan Audio Devices at top of Audacity then in Device Toolbar, choose the USB audio CODEC for the converter as the Recording Device.
If Windows doesn’t see the device, please try the full procedure in the green box “Detecting USB and Firewire devices” on this page: Audacity Manual . That applies to Windows 10 too.
