Synchronising MP3 and lyrics
I have a very small MP4 player which is able to play an MP3 music file and display on its LCD screen the words of the music song with synchronism between the two.
Is your editing program able to do something similar for use on my laptop – playing an MP3 song with the lyrics for the song being displayed on the laptop screen. The .mp3 and the .lrc files will need to be synchronised for the display.
If your program is not able to do this, can you suggest where I should explore next?
Audacity does not support lyrics.
If you are on Windows you could try this: http://sourceforge.net/projects/antonieplayer
or search Google for other options.
stevethefiddle,
thanks for your suggestion - I will follow up.
