Sync to external MIDI time Code
Hi Folks,
Is there a way to sync Audacity with an external digital workstation, like a Roland VS 1680, where the Roland is the MASTER unit sending MIDI Time Code to sync with Audacity. That way I get the best of both worlds because the Roland unit is a breeze to record audio. I’d be using the sync to control MIDI instruments like a synth, so audio and digital inputs are syncronised. Thanks for any suggestions.
No. Audacity does not do MIDI.
Well, if you already have a midi file, Audacity can play it though the OS. But that is the extent of it.
