I want to sum to waves, and have the output go to a created track. I’m at the prompt and i am using:
(add(hzosc 10)(hzosc 100))
Any suggestions? All help would be appreciated.
Thanks
Vf
Thanks
Vf
The answer was in the question: “sum”…
(sum (hzosc 10)(hzosc 100))
The result of the above code will go +/-2 , so you’ll need to multiply by 0.5 to keep it from clipping …
(mult 0.5 (sum (hzosc 10)(hzosc 100)))
hah, so i am reading the wrong docs i guess…
where can i find the right ones?
thanks.
Vf
See here: Manuals and reference material
