Suggestions for time stretching/pitch shifting effects?
Hi all,
I was looking for some good VST’s effects for changing the tempo without changing the pitch of a voice and vicebersa. I would like to get plugins which shift the audio speed or pitch without changing its intonation; I said this 'cause I only have found plugins like autotune/gsnap, and I don’t like so much the quality of the default soundtouch library.
Do you have some recomendations? Thanks a lot!
Audacity has Change Pitch, Change Tempo, and can do both simultaneously.
As for time-stretching, Audacity comes with PaulStretch.
I recently found this free Dblue-stretch VST , (although it’s almost a decade old ).
[free] Kerovee VST can do a fair male to female conversion , ( and also does autotune-type pitch correction ).
Madshifta is a free pitch-shifting VST which works in Audacity.
A list of VSTs which allegedly work in Audacity is here … Missing features - Audacity Support
and “Sliding Time Scale / Pitch Shift” http://manual.audacityteam.org/o/man/sliding_time_scale_pitch_shift.html
