Greetings, everyone.
Disclaimer
I’m not sure if this is the appropriate place to seek help for my issue, seeing that I don’t have problems with Audacity directly, but I have seen one other SubZero SZ-AI2 related post here and I’m planning to use Audacity later down the line, so I’m giving this a shot.
Introduction
I am pretty new to both elGuitars and audio interfaces, so I might come across as silly, but please bear with me. I want to listen to & record my guitar on my computer, so I purchased the specified audio interface, but I’m running into issues using it. It won’t pick up on my guitar strums.
Equipment
Guitar
https://www.ibanez.com/eu/products/detail/grg121dx_2y_03.html -
Interface
https://www.gear4music.com/Recording-and-Computers/SubZero-AI2-USB-Audio-Interface/25KZ -
Headset
https://www.turtlebeach.com/products/elite-atlas-headset
Installation
- Microsoft Windows 7 Ultimate
- Audacity 2.2.0
SubZero SZ-AI2 2x2 USB Audio Interface Driver & Control Panel: For PC / For Mac.
Configuration
- Computer ↔ SubZero (USB)
- Guitar → SubZero (Jack/Instrument cable)
- SubZero → Headset (AUX (using jack to AUX adapter))
Sound:
Both output and input in Windows have the SZ-AI2 device set to standard unit (but not standard communication unit)
Expected Results
At this point, I should be able to see the sound bar in the SubZero control panel under input move when I strum the guitar as an indication that it’s picking up sound from the instrument. I should also be able to hear/monitor the sound through my headset.
Actual Results
The SubZero does not react or give any indication that it’s picking up sound from the guitar (neither does Windows).
I can’t hear my instrument through my headset.
I am able to hear sound through the headset if I’m playing audio from my computer, such as a YouTube video, but the volume is weak and blurry and when an ad appears, there is a lot of white noise coming through.
Last Words
I have tried messing with the knobs on SubZero. Turning GAIN 1 up and down, toggling INS 1 on and off, setting MONITOR to OFF, MONO, STEREO, toggling +48V phantom power, rotating the master volume and the headphone knob.
I have even tried turning the jack cable around slightly and switched to MIC 2 just in case I could find a connection issue.
I have restarted my PC after the driver installation.
In case this information is overwhelming, know this: I’m just trying to be as clear and informative as I possibly can in case you spot anything wrong and for other with a similar issue as mine can relate.
Beforehand: Thanks for any response/criticism. Kind regards.
