Hello everyone! I’m new here and I’m using Audacity to create my subliminals. I recorded my voice into the Parrott App, added the mp3 file at 44100Hz 16-bit to Audacity and also the thunderstorm sound to cover the words. The subliminal was created but there is an annoying screeching voice in the background, which should supposedly not be heard. What am I doing wrong? Can anyone help me?
Any “voice” you did not add is probably EVP, a/k/a Rorschach audio
You lost me there. Let me explain further: before combining the two sounds (my affirmations recorded on an app and the sound of the rain) my voice was as usual. I’ve already heard quite a few subliminals but you never get to hear any screeching sound in the background. I know I’m doing something wrong but I just don’t know how to fix it
Recordings of wind and rain contain a lot of noise , e.g. Brownian noise - Wikipedia #
such noise can be misinterpreted as speech: audio pareidolia/EVP.
There’s more than one way to make a subliminal. It might help if you tell use what you’re doing.
Just mixing a quiet voice with a louder sound is one way to do it, but that shouldn’t create screeching.
You can get distortion of the combined sounds "try’ to go over 0dB. But if the quiet sound is down around around -20dB that should be insignificant. And lowering both sounds can completely prevent that.
Got it now, it wasn’t that the problem though. Thanks anyway.
Did it. lowering the voice down to -20dB did the trick. Thanks a million!
