I am making a subliminal with the subliminal Nyquist prompt that makes the sound file at 17.500 hz.
I have 3 different sound files, a female voice on the left, a male voice on the right and my own voice in the center at 44.100 hz. The voices have different pitches of course so how will it work by converting the file to 17,500?
Another question is about volume. If I listen to the raw file before I turn the file into a subliminal one, I can assume the sound level is the same, or is there something I should be aware of.
I use the raw file to assess how loud the sound is before I use my subliminal.
It doesnât âconvert to 17500â. It âmodulatesâ the amplitude of the sound with a 17500 Hz âcarrierâ, which is the same process as AM radio, except that AM radio uses a much higher carrier frequency (commonly around 100,000,000 Hz). Thereâs a description of AM radio encoding on Wikipedia: AM broadcasting - Wikipedia
Okay I see, Donât claim to know the technical stuff, but I know it works but just want to know I do it right.
When I have 3 tracks, 2 mono tracks and one stereo track, would it make any difference if I use the .ny prompt file separately on each track before mixing it to a stereo track, or do I have to mix the 2 mono tracks and the 1 stereo track before using the .ny file?
And if I also make binaural beats in audacity with two mono tracks with a carrier frequency of 50 Hz on the left and 95 Hz on the right, will that also have an implication when I mix the files to a stereo?
I dont want it to be distorted.
My native language is not english so hope you understand and sorry if the questions seems stupid.
Why does that matter if you canât hear it? Surely, if your subconscious mind is able to demodulate AM encoded audio, it could also remove the distortion
A subliminal recording plays affirmations at a frequency beyond the standard hearing threshold - usually 16,000 - 17.500 Hz. They play at this frequency so the affirmations can bypass the logical and reasoning part of your mind, the conscious mind.
Therefore, it doesnât challenge or reject the affirmation you are trying to impress into the subconscious mind. Because the conscious mind cannot hear the subliminal playing, all the affirmations from the track enter the subconscious mind and the reprogramming process begins.
While you cannot consciously hear the affirmations, the audio of the affirmations produce waves of sound that travel down the ear canal and send vibrations to your eardrums. Your subconscious mind is able to decipher these vibrations because these are the same vibrations that make up audible sounds.
This is because sound waves exist as variations of pressure in a medium such as air. They are created by the vibration of an object, which causes the air surrounding it to vibrate. The vibrating air then causes the human eardrum to vibrate, which the brain interprets as sound.
In the simplest terms, we âcatchâ these vibrations in our middle-ear where theyâre transferred into pressure waves. These waves are then passed through fluid into our inner-ear, or cochlea, where theyâre translated into signals our brains can interpret.
We are talking about tecnology here, so even though the subconscious mind can understand alot, it cant understand distorted audio if theres no data reaching your mind.
Thats why subliminals on youtube doesnt work, because they are being compressed. Only supraliminals work on youtube.
I understand you have a belief that it doesnât work but I know it does (for several reasons) but I want help with the technical stuff to not get a distorted audio
Mix your audio tracks to a single track first. That way you can check that itâs not distorted (because you can hear it) before you make it inaudible.
Do you know how I can relate to the sound level with this frequency?
Would the sound level be the same as the original file? So I can compare the sound level by first listening to the raw edition to know how loud it is?
âIt doesnât âconvert to 17500â. It âmodulatesâ the amplitude of the sound with a 17500 Hz âcarrierâ, which is the same process as AM radio, except that AM radio uses a much higher carrier frequency (commonly around 100,000,000 Hz). Thereâs a description of AM radio encoding on Wikipedia: AM broadcasting - Wikipediaâ
And by this, what Hz am I then listening to if the original tracks were 44.1000 Hz? Maybe I misunderstand this part.
I guess you mean â44100 Hzâ. That number refers to the âsample rateâ. Hereâs some information about what âsample rateâ means: Digital Audio Fundamentals - Audacity Manual
What do you mean when you say âconverted from 4000 Hz to 8000 Hzâ ?
Assuming that you are still talking about modulation: The amplitude of the modulated signal depends on the amplitudes of both the modulator and the carrier, less any losses from filtering.
If I recall correctly, the âSilent Subliminalâ plug-in that I wrote applies positive gain to compensate for some of the filtering losses, so that the output level is closer to the input level than it would otherwise be.
Basically, when we say the affirmations are inaudible, it means that the human ear cannot hear the frequency because the auditory hair cells in your ear that are responsible for processing (hearing) this pitch have become very insensitive (usually a result of aging).
This is where the confusion occurs because so many people are led to believe that the brain canât process something we canât hear, and that is very incorrect. Your ears are responsible for hearing noises, but itâs the brain (auditory cortex) thatâs responsible for processing and decoding the information.
Sound is what we hear while the brain interprets it. You can totally not hear something and still interpret it on a subconscious level. This is how subliminals work. Just because you canât hear the affirmations does not mean it isnât being picked up by your brain. We know this because of the way sound waves work.
When you play the subliminal, you obviously wonât be able to hear anything, but does that mean the affirmations are just not there? Of course not. The sound waves are still there, causing your eardrums to vibrate where your brain processes and decodes these vibrations. The only difference is that your ears arenât hearing it.
There are examples of this done through clinical trials where the brain was affected by a sound that exceeds even that of subliminals. That is evidence that sound can be picked up by the brain despite the ears not being capable of hearing it. This should debunk the âif you canât hear it then itâs not going to your brainâ statements.
TL;DR: Human hearing plays a completely different role when it comes to processing auditory sounds. Itâs the auditory cortex of the brain that decodes the sounds you hear. You can hear something but itâs the brain that has to process what is being said. Because a subliminal canât be heard by your ears, itâs imperceivable to the conscious mind, allowing the information to be processed on a subconscious level (beyond critical awareness).
Yes. And because the hairs donât vibrate, they donât stimulate the mechanoreceptor, so the mechanoreceptorâs afferent neurons do not produce a response, so no signal is sent to the brain, so there is no information for either the conscious or subconscious to react to.
However, âsilent subliminalsâ can be an effective placebo - that has been illustrated through several well documented clinical trials, such as the study by Manuel Froufe and Cecilia Schwartz, published in The Spanish Journal of Psychology , Volume 4 , Issue 1 , May 2001 , pp. 19 - 25.
NĂĽh that is not how it works. Theres a difference if thw hair cells produce âsoundâ or it will give information. Placebo cant give an ex back or influence others behavior etc. But I accept tour logical opinion
Is the cochlear really that efficient? Do you really know with certainty that 17KHz tone will only vibrate the hairs responsible for that frequency range and donât stimulate other hair cells.
A bit ago we developed coder software that would create subliminal tracks in the Lowery method. We also created a decoder which would bring voices back down to the normal audible range. Engineers and developers like this because it proves the voice is actually posted as high-pitch modulation. I can, for example, send you a SiSub track and you can pull it back down to normal voice.
There are some restrictions. You canât start with multiple voices and/or stereo configuration. You get one technically correct, clear voice in monoâfull stop.
If that appeals to you, we can supply the code and instructions.
If you insist on the technically-shaky higher quality and complexity, then youâre dabbling in magic without the techies.
Another couple of points. I always understood the subliminal method depended on super simple messages, repeated. Stop Smoking, Stop Smoking. This isnât a good place for complex messaging and stereo production. Nobody ever claimed that subliminal transmission worked in stereo.
I think youâre producing the quiet, plain-audio âbackground musicâ messaging found in grocery stores. âBuy Cheereos, Buy Cheereos.â
We recommend you place a clear, normal-voice message at the beginning of the track. You set this voice for comfortable listening and then donât change anything through the course of the message playback.
âSet my voice for comfortable listening. Not too loud nor too quiet. The message will start now.â
In case nobody hit this yet, you canât use MP3 for any of this. One way MP3 gets its small files is to inspect the content for sounds normally inaudible, and deletes them.
Another thing it does is shift tones around slightly for efficient compression. You normally canât hear MP3 doing this, but thatâs deadly for a subliminal message which depends on everything being in exactly the right place.
