hi,
Request : Subliminal Audios with Positive Affirmations App (Software)
Record human voice or Use already recording affirmations file.
Mix it with music (masking) so lister only listen music while the affirmations go to sub conscious.
Copy paste the affirmatins to match the length of the music file.
increase the length of music by copy paste to 30 minutes as healing music is normally 5 minutes.
As affirmations are recorded by humans so the gap b/w 2 affirmaitons are not fixed, this software should
give the facility to make a constant gap of 4 or 5 seconds b/w 2 affirmation sentences. -
Can add Alpha and Theta sound waves to music track or the final track.
Can add Isochronic tones to music track or the final track.
Can add binaural beats to music track or the final track .
Fade in Fade out option
Masking and Reverse Masking option
Ability to make make 432 hz music or convert the final Audio to 432 hz & 528 hz.
As should be an option to make an exact gap of 4 or 5 second b/w two sentences (affirmations).
or simply make a Tutorial on how to make subliminal audios using Audacity, Sound wave and Adobe Edition
in text, images and video form & make a small app of it of 1 dollars.
there are about 50 million people who listen Subliminal Healing Music with Affirmations.
famous sites are Vortex Success, Sprudio and Mind movies…
hope you work on that software.
regards
