Strange glitch please help everything is disappearing :(
When I have alot of sounds in a project, zooming out makes everything disappear :frowning:
I am no programmer but I have no idea how this is even happening when I think about it.
I just wanna make a funny Baldi’s Basics cover of a song and this is all I have!
Explanation: Having a large amount of sounds in the project and then zooming out activates it, When you hover over the UI buttons after this, it all disappears and doesn’t come back until you re-launch the program. This also effects the audio waves, as they disappear too.
The possibilities…
This could be a display driver problem, or an accessibility setting, or possibly the program is running in Compatibility Mode if you are using Windows.
i am indeed using windows but i dont know what compatibility mode is ill go check that out
