I can record and stop like normal at first, however when I try to play what I’ve recorded It simply glitches at the area I’ve selected and makes no sound. I thought this was problem with my version of Audacity, so I downloaded the newest version however the same problem occurred. I’ve made sure that I clicked the green arrow (start) button each time ofc, and when I click the stop button everything works like normal, that is until I try to play back the audio and it glitches again. Here’s a screenshot:
As you can see the stop button is colours indicating I have pressed the play button, and the line that follows where you are on the track stays in that one spot and jiggles around a little.
