Strange bug in distortion effect
Hello.
I’ve found a bug in distortion effect. When I have applied effect, this distortion is not, like in preview.
Please, could You fix this bug, or have You some recommendations for other distortion effects? It can be VST or Nyquist too.
Thank You.
Marco
Which version of Audacity? Which operating system?
I use latest version of Audacity and Windows 10.
On Linux I can measure a very small, but inaudible difference with the settings that I tested. Perhaps there is a bigger difference with different settings. What setting are you using?
Are you applying to a mono or stereo track?
