Still Can't Export by Track in Aud4
I have the newest version which is supposed to allow multiple exporting by tracks like in Aud3 but it still won’t work for me. Any help would be appreciated. I wish I hadn’t moved to Aud4 from Aud 3 TBH.
In what way does it not work for you?
I use that option and it still only exports the entire project as one file, ignoring the tracks completely. It puts a “1” in front of the file and makes it as if that’s the only track.
I should say I’ve been using Aud3 for years and never had an issue exporting or making track labels.
Or is what I’m thinking of as exporting tracks used to be exporting labels as individual tracks.
So I have to break the project up where the labels are into separate tracks now???
Never mind. I am a doofus. I have figured it out.
