Hi all,
Been using Audacity for years and this is the first time I’ve had this issue. Recording playing along just fine and then suddenly stops and keeps repeating the part of the track it is on.
Is there a fix for this or am I going to have to redo the interview?
Thanks,
BKB
Do you have looping enabled? You may need to click the loop button to disable it.
Thanks LWinterberg! No, I did not have looping enable but that led me to removing looping from the file. Problem solved!
Thanks again,
BKB
