Audacity 3.0.2 in Win 10 Pro 64bit
Can I stick two clips of different volume together and equalize the intersection to a smooth transition?
TIA leo48
If you want the clips to be different volumes (you don’t want to amplify them to the same volume), then you could “crossfade” from one to the other.
The easiest way to crossfade two audio clips is with the “Crossfade Clips” effect.
More detailed information about crossfading: https://manual.audacityteam.org/man/creating_a_crossfade.html
There is also a “Crossfade Tracks” effect: https://manual.audacityteam.org/man/crossfade_tracks.html which is more complicated that “Crossfade Clips”, but more flaxible.
