Splitting a track
When I search this in the manual, it seems to refer to making two tracks out of one. What I want to do is cut out a section of a track and remove it while the following section remains in place, i.e., not closing in to fill the void. Kind of like one does with splitting a clip in iMovie.
Mac OS 10.14.6
Audacity 2.2.2
If I understand correctly, you need to do “Split Delete” (Ctrl + Alt + K). See: Edit Menu: Remove Special - Audacity Manual
Yes, that was it exactly. Thank you!
