Split tracks automatically? How?
I want to dub some cassettes over to WAV files.
What I don’t want is to record one side, then have to manually split each song into a separate track.
What I want is for Audacity to automatically split the album side into individual songs.
And yeah, I know that some songs blend into each other, with no silence in between.
The Audacity manual is EXHAUSTING to read. I want the exact answer, and NOTHING ELSE. I don’t have time or energy to become an Audacity Jedi Master.
…Or you could try a google search… :grinning:
Try Analyze > Label Sounds, then File > Export Multiple > Split Files Based on Labels.
Select the entire track or the portion of the track you want to split, Then go to Edit Audio Clips Detach at Silences.
Visit here: [advertising link deleted]
