Spitfish Not Working
Hello, I am unable to enable my Spitish plugin. I tried reinstalling it multiple times, but nothing happened. I also have YouWa and Gsnap not appearing. What did I do wrong? I can’t record until I fix these issues. Grallion 2 is the only one that works right now, It says C:\Program Files\Audacity\plug-ins\SPITFISH.dll is incompatible.
Is a 32-bit plug-in. It only works in 32-bit versions of Audacity.
The default version of Audacity served up is 64-bit. You have seek out the 32-bit versions.
There are free 64-bit de-esser plugins … Cant use Spitfish plug in - #2 by Trebor
