I want to speed up my voice which I have recorded, but when I do so with Audacity the pitch would be altered. So right now I am exporting the file to mp3. Open it in VLC and there I speed it up to 1.5x or 2x, then I record it with a screen recorder to a .mp4 file and then import that file into Audacity to export it to .mp3. This works, but if it can be less tedious that would be preferred.
I found a plugin and installed it into Audacity, I only needed to enable it, and when I clicked on the disable tab, I saw that ‘Change tempo’ and ‘Change speed’ were disabled. I think I might have disabled them two years ago. Probably due to their ineffectiveness regarding the alteration in the pitch. Again thanks for the tip man
