Special Effects, Curve Editor, Modulation
Special Effects
Repeat
I really like this effect but would like a few adjustments. Instead of just having audio repeat at same intervals based on selected audio. I would like a lerping check box and a random check box.
Random
Instead of repeated audio at intervals base on selected audio length, randomise the audios repetition intervals length to give a more distorted repeat. Random repeat should also auto mix repeated audio because of its unpredictable placement of audio.
Lerping
lerping repeat should repeat audio until it reaches target length. The further away from target length the longer the intervals, the closer to target the shorter the intervals of audio repeated. This will make it much easier to achieve more complicated sound effects.
Modulation
modulation of real time effects would be very useful. Modulation tracks that are child of audio tracks and modulate any real time effects properties.
Curve Editor
A decent curve editor for Time track, Envelope, modulations would be very helpful. The Time track is a little awkward to use, the time track should be a child of audio track and only affect that audio track.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
