I am having problems recording using my inbuild pc microphone array. The inbuilt Sound Recorder functions OK which suggest that the Settings I have on Audacity are incorrect.
Advice would be appreciated.
What kind of “trouble”?
Check your Windows Privacy Settings.
And make sure Windows “enhancements” are turned OFF.
SOLVED
My fault … settings between pc and Audacity were not correct. Below are my corrected settings . Thanks for guidance.
