Sound in speakers
When I plugg in the loudspeakers to the computer it stops recording. Same if i connect BT earphones. Why?
Åke
Normally, your Recording Device is independent of your playback device.
Except if you are using “loopback” to record whatever you are hearing out of your soundcard (or other device). In that case you have to select loopback for wherever the sound is actually coming out. (Loopback MIGHT not work with your Bluetooth device.)
Normally, you select an audio input unless you are recording streaming audio and there is no physical input.
