Hello. I’ve been reading about SoapVoiceCleaner. It seems like a compelling plugin, possibly making the whole workflow much easier. I’d like to give it a try, but I have a Audio-Technica AT2020USB Plus mic. I understand that it is pre-programmed for a very limited range of mics, and otherwise just sort of has a general use mode. Since mine is not one of the pre-programmed mics, how much benefit can I expect? I understand that there is a free version, and I will try it, but I won’t know much about the performance gap between my mic and the included ones. How close will it be? Would I be better off elsewhere? Thank you.
If all it does is adjust the EQ and compress, then the free version of TDR Nova can do all that … TDR Nova | Tokyo Dawn Records , (it has some vocal presets).
