When I launch Soap voice cleaner in Audacity at the first time, fine, wonderfull. But at second time, nothing, nothing. And I don´t change anithing. I spent the $73.19 to buy the plugin on MuseHub and installed it, last 11 august.
The first time Soap voice cleaner is wonderfull, but…
Please help.Thank you!
Coq1995 - August 21 2025
Can you send a screenshot of how Audacity and Soap looks like when it doesn’t work?
Hey there! Tom from Soap Audio here.
Voice Cleaner is accessible two ways in Audacity: offline and real time.
To use the offline version, highlight the audio that you would like to process and choose Voice Cleaner by Soap Audio in the “effect” dropdown at the top of the screen.
To use the real time version, select Voice Cleaner from the “effect” dropdown to the left of the audio, just above the gain and pan.
Let’s get it worked out for you!
I think I understood and now its working.
Big thanks!
Unfortunally, Audacity is not accessible for me in offline and real time.
None of your graphics appear that allow you to make changes according to the needs of the loaded audio.
Coq1995 - august 25th
I´m working and I find this message of Audacity: “Audacity automatically disability a plug-in (voice cleaner).” But it not show whay it did that..
I am having the exact same issue, and have submitted a request (with my own version of the same screenshot) through MuseHub, but keen for an answer here if it will be faster.
