hello
lost !!!
i would like to slide the single selected from 1.045 to 1.035
without moving anything else
thanks for your time
Adcty 3.0.2 mac 10-12-6
hello
lost !!!
You’re using a older version of Audacity which has “time-shift tool” to slide tracks on the timeline …
hello
thanks for your prompt answear but i’m a novice ! so ! i need a more detailed explanations .
schould i create a new track
when following instruction from the manual , from the edit clip boundaries , with using the time shift ,
etheire side of the line move and not ONLY my selections .
mac 10.12.6 i suppose i cannot update .
thanks a lot .
More than one way to skin a cat: this is one way to do it …
It’s quicker using the “hotkey” shortcuts.
hello
perfect thanks a LOT .
