two people, one has limited internet usage, both have same wav files and folder structure. Is there a way to save the project file to not include the audio files so the project file can be sent to the other person and the project recreated on their system using the files they already have?
In a word, No. The audio is stored in the project file.
This is possible in Audacity 2-x, which allows referencing external files. It also is possible in Soundscaper, a fork of Audacity 4, which in the desktop version also references files.
Note that any destructive edits (like applying effects from the effects menu) create new waveform data and thus must be synchronized separately.
Thank you very much for the information.
