Significant Slowdown of Sound Playback After the Latest Update
After the recent 3.6.1 update, the program has become significantly slower in starting sound playback. Sometimes, several seconds pass after pressing the play button. This makes working in the program almost impossible. Previously, everything worked quickly, so the issue isn’t with my hardware. Has anyone encountered this? How can it be fixed? Ideally, reverting to the previous version would be best, but it seems that’s not possible.
Who said that? You can get older versions of Audacity from here:
Do you know which one worked?
After you install the replacement program, Tools > Reset Configuration.
You can get odd behaviors if you’re not working on the local drive. Audacity does not like USB, external, network, internet, or cloud drives.
