"Show scrub ruler" issue
Hi everyone, been using Audacity for close to 10 years, mostly on Debian, ( don’t judge me) :wink:
I thought I’d try something different, now I’m using 3.4.2 on Linux Mint. It seams to be working OK, except there seams to be problem saving configurations. After loading a project the scrub ruler doesn’t automatically load, even though in Edit | Preferences | Interface the “Show scrub ruler” check box is checked.
The work around is to just do this every time. Edit | Preferences | Interface | OK
But I did a bit of investigation into this and found that the file audacity.cfg was written to multiple times.
gitsy@gitsym:~$ inotifywait -m /home/gitsy/.config/audacity
Setting up watches.
Watches established.
/home/gitsy/.config/audacity/ MOVED_FROM audacity.cfg
/home/gitsy/.config/audacity/ MOVED_TO audacity.cfg.bkp
/home/gitsy/.config/audacity/ CREATE audacity.cfg
/home/gitsy/.config/audacity/ OPEN audacity.cfg
/home/gitsy/.config/audacity/ MODIFY audacity.cfg
trim… [ over 100 actions for just closing Audacity OMG! :crazy_face: ]
/home/gitsy/.config/audacity/ CLOSE_WRITE,CLOSE audacity.cfg
/home/gitsy/.config/audacity/ DELETE audacity.cfg.bkp
And it still doesn’t load show the scrub ruler, even when I load a project. I deleted the audacity.cfg file in the hopes that new .cfg file would be created a fresh. I also did Tools | Reset Configuration but no luck. Has anyone had an issue with this, and found a solution?
P.S. I completely deleted audacity, changed repositories and reinstalled, but it still doesn’t save the scrub ruler.
If this is the bug I think it is, resizing the window or just opening and closing the preferences works around it. I think we fixed one case of it in one of the more recent releases? So maybe try 3.7. Otherwise, it’ll definitely be fixed in 4.0
