Shortcuts import xml not working in Audacity 4
I’m unable to import the Audacity-keys.xml file containing my shortcuts from Audacity 3 (Mac)
Preferences>shortcuts>Export… worked without problems in Audacity 3, saving a .xml file, but when trying Preferences>shortcuts>Import… in Audacity 4 there was no indication the import worked or not and when I inspected the .xml file I could see the standard shortcuts but none of mine from Audacity 3
I inspected the .xml files and the format is quite different. For example, the “add label” shortcut appears in Audacity 3 as:
command name=“AddLabel” key=“B”/
but in Audacity 4 as
SC
key label-add /key
seq Ctrl+B /seq
/SC
A separate issue concerning making this post: when posting this topic I was unable to add any of these “Optional tags…”: shortcuts, import, xml and I also had trouble showing the above .xml file contents because the < and > symbols prevented them from appearing
Use the “Preformatted text” button in the message formatting bar. </>
<this is an example of using the Preformatted text button>
