Shortcuts Get Reset on Restart
Every time I close Audacity 4, my shortcuts get removed/reset. Specifically I’m setting a CTRL+Shift+L shortcut for ‘Silence’. I did a few others as well, but I got tired of resetting them every time so the silence one is my primary test case right now.
I made sure I’m up to date on the latest version. I hope this is another stupid me issue with an easy fix. I’m on Windows.
It’s not just you.
No, it’s not you. It’s a stupid Audacity issue.
I run Linux, and was considering installing Windows (blech!) on a spare machine to see if Audacity 4 would behave better for me. It appears that may be a waste of time, but I may still try it.
BTW, I’m actually the one who submitted the bug report on Github.
Well, glad it’s not just me. But bummer there’s no fix yet.
FWIW I’m on Mac and my custom shortcuts don’t disappear. They’re in a shortcuts.xml file. It might be worth finding that file on your system and looking at it, maybe deleting it so Audacity will re-create it next time it starts?
FWIW, I just downloaded version 4.0.2. I got the same crap. Shortcuts didn’t work.
Billw’s post gave me an idea. I deleted the .cfg (config) file, reset my shortcuts, and they are now working. At least for now… I was able to complete a small project with AU4, so that’s definitely progress.
I found my shortcuts.xml file and deleted it. But I still have the same issue.
I opened up the file in a text editor and I see the custom shortcut/s that I set. So they are saving. But when I close and open up Audacity again, it doesn’t load in the shortcuts in the xml.
I tried using the manual ‘Import’. That works (provided I copy it to another location and import the copy), but I still have to do it every time I open Audacity.
I’ve added your report to Github.
