Does anyone know whether there is a keyboard shortcut to go to the last track in an open project? If there is no such shortcut, can it be assigned as a custom shortcut in the program?
When the “Full” set of default keyboard shortcuts are set, “Ctrl + End” moves focus to the last track.
(https://manual.audacityteam.org/man/keyboard_preferences.html)
Although the End key is set for the command “Cursor to — Project End,” the cursor is not moved to the last track within a project when I press the key.
Yes, that is correct. Instead the cursor is moved all the way to the right. As Steve says, to move it down, you need to use “Focus - Move Focus to Last Track”:
Thank you. Now I have been able to assign the Ctrl + Home and Ctrl + End shortcuts to move the focus to the start and end of a project.
