Shortcut Key "close the only track"
Win10/3.1.3 If it weren’t for shortcut keys i wouldn’t use computers (grin)
The topic “How to close multiple tracks from Audacity window” came closest to answering my question, when it pointed me to “Remove Tracks”.
I work nowadays with one track - recording text for audiobooks, and so I have a single track which goes through an R-X cycle several times until I have accumulated 45 minutes of audio clips.
So I:-
Ctrl+A to select all the clips of the track
Ctrl+Shift+E to export to this track’s folder which I set with Ctrl+P just an hour ago,
then I click on the little “x” to remove the track before
Ctrl+Shift+I to reload the recorded track as a single clip.
In the File menu there seems to be no command to do what I want.
In the Tracks menu the Remove command pops up a message “Disallowed: Remove Tracks requires one or more tracks to be selected” (sigh!)
Short of dashing off a quick Audacity macro to get the job done, is there an appropriate command to effect that “click on the little x” operation?
If word gets out that I am using the mouse, I will lose those few friends who remain (grin)
Thanks
Chris
Of course, you already know about Ctrl+A to select all tracks.
Yes, but…
  1. By default it doesn’t have a keyboard shortcut (you can add one - see image below)
  2. The track must be selected (If it’s not selected, then “Ctrl + A” will select it).
See:
https://manual.audacityteam.org/man/keyboard_shortcut_reference.html#extra_track_submenu
Shift+C closes the focused track.
This default shortcut is only in the full set of default shortcuts - see top of that page.
Thanks David.
