Short cut for "Rename Track" (Set track name)
Rename Track” (Set track name) is missing in shortcuts menu. QQ
None of the menu items in the drop-down menu in the track control panel are accessible in the Shortcuts panel.
The command “Set Track…” from the Extra > Scriptables II menu is available.
To see the Extra menu, go to Interface Preferences and enable “Show Extra Menus”.
Thank you @billw58 ,
I also found this feature at the location you mentioned earlier. However, for someone who just wants to rename a track as quickly as possible, the popup is too complicated, and I sincerely hope that the “Rename track” function in the drop-down menu of every track should appear in the shortcuts menu to make it easier.
Additionally, all common functionality of scripts in add-on menus should become standard built-in functionality.
In His Love,
Yuktesha
