I have 900 or so songs from different sources that play off of a USB stick in the car. The problem is some of them are really loud and some are very soft. I am constantly changing the volume on the radio. I have been editing them as best I can with the adjust it with the slider to the left of the track, I can also double click to set a value. The problem is that this value is reliant on the selected track and not the same on all tracks imported. I wish to be able to set all tracks imported to the same volume output. Is this possible.
OK thank you, just what I was looking for, but I spent an hour looking for the download and cannot find it. I found all the information on how to use it and how to download it but I cannot find the file to download. Maybe it is just too early in the morning and I only had one cup of Java. I found the page with all the Nyquist downloads and it was not there.
Update: I just tried macro in Audacity 2.3.0 , it is possible to batch-process all the files in a folder/directory.
900 is going to take some time though, probably several days on one computer.
